If you guys have not seen this amazing camera here is a quick demo on it:
$7495.00
Buy a FLIR E60 or FLIR E60BX and get one of the following for free:
Extech MO297 Moisture Meter - $649.00 value
Extech EX845 $369.99 value
Apple Ipod Touch - Approx $200 value.
In addition through the end of May AC Tools will throw on a free building and roof diagnostics IR course. You can upgrade this course to an ASTM certified building level I course for $500.
As well as being the best value, the moisture meter fits the HI industry perfectly. It is both pin (plus additional attachments available) and pinless as well as being a full digital psychrometer.
Here are the key specs on the camera:
E60
-Focal Plane Array detector with 320 x 240 pixels infrared resolution (76,800 pixels)
-Wide temperature range: -4°F to 1202°F (-20°C to 650°C) with 2% accuracy
-0.05°C @ 30°C Thermal Sensitivity (N.E.T.D)
-Manual focus, 4x continuous zoom
-Built-in laser pointer, 3.5" Touch-Screen LCD display
-Built-in 3.1 Megapixel visible light digital camera with bright LED lamp for poorly lit environments
-Functions include Scalable Picture-In-Picture, Thermal Fusion, Voice/Text —Annotation, Laser Pointer Marker, IR Window Correction, Instant Report
-Measurement modes: up to 3 movable Spots, up to 3 Areas (Min/Max/Average), Auto Hot/Cold spot marker, Isotherm (Above/Below), Delta T
-METERLiNK™ Bluetooth® Wireless communication
-Wi-Fi Connectivity allows to send images and data to mobile devices
-Video Recording/Streaming, Thumbnail Image Gallery
-Memory card slot for image storage (more than 1,000 Radiometric JPEG images)
-Complete with Memory card, Li-Ion rechargeable battery, power supply, USB and Video cable, hand strap, lens cap and hard carrying case
-Includes FLIR Tools software for analysis of radiometric images
E60BX
-Temperature range: -4°F to 248°F (-20°C to 120°C) with 2% accuracy
-0.045°C @ 30°C Thermal Sensitivity (N.E.T.D)
-Functions include Scalable Picture-In-Picture, Thermal Fusion, Insulation & Humidity Alarm, Voice/Text Annotation, Laser Pointer Marker, Instant Report
-Measurement modes: up to 3 movable Spots, Area (Min/Max/Average), Auto Hot/Cold spot marker, Isotherm (Above/Below), Delta T
-Thumbnail Image Gallery function allows quick search of stored images
-Complete with Memory card, Li-Ion rechargeable battery, power supply, USB cable, hand strap, lens cap and hard carrying case
Jason Kaylor - JJ
VP of Specialty Products
AC Tool Supply
877-207-1244
