Originally Posted By: rcooke This post was automatically imported from our archived forum.
jwilliams4 wrote:
I have looked all over the 2002 NEC for the code about floating neutrals
in a sub-panel and have come up dry. Can't even find the previous
post on the subject, but I know there are some 'cause I read them.
Any body got some numbers for me so I can read the NEC about it?
HHEELLPP!!!!
Thank you.
Question Not having a code book and not wanting one.
I wonder what you trying to find about floating Neutrals .
very uncomin and only used in unusual circemstances.
Just wondering if I can give you some help .
Originally Posted By: brian winkle This post was automatically imported from our archived forum.
That's because the NEC does not specifically address sub panel neutral connections. However look at 250.24(A)(5).
This is a controversial subject with a lot of sparkies, especially the older ones. For many years 3 wire sub panels were installed. Were they ever legal?
There is a system of floating neutral . Very unusual very uncommon only used where you can not get a ground rod into the ground . 3 wire systems where not allowed in Canada . All sub panels had to carry a ground with them . You can only have one ground in Canada and that is at the primary panel .3 wire system lead to all sorts of Eddie currents.
I learned about floating Neutral in the fifties have never seen one . I that is why I wanted more information on what is being talked about.
