Anybody have any good information of foam spray roofs about 5 to 6 inches thick. What should I be looking for during the inspection? Any help would be appreciated. Information regarding this type of roof on the net is limited and just wanted others opinions.
Hi to all,
I inspect a lot of SPF roofs down here, the biggest problems I find are from, Blistering due to moisture, some jobs look like a relief map of the moon!! (the blisters rupture exposing the foam), Mechanical damage caused by tree limbs or tradesmen damaging the surface when swapping out mechanical equipment, poor application of UV resistant coatings.
Here are a couple of images, including one from this mornings job.
Regards
Gerry
BTW the last image is what they should look like
Gerry, could you elaborate on this?
I am looking at SPF roof here that I have never seen nor know how they perform, but your pictures seem to indicate a Ballast on the first three pictures and the ballast size seems different and the fourth picture appears to be more of a sand texture. Are those the same roofs?
Confused.
Why the ballast? aesthetics? or performance?
Thanks
Marcel
Hi Marcel,
SPF roof s are very common down here on commercial and condo structures, either ballast or elastomeric sealants are used as the finish (sometimes both), personally I perfer the sealant roof as it seems to protect the foam better. On some ballasted roofs the agregate itself causes problems from wind scouring (they use crushed stone rather than river run, so any movement of it (or heavy traffic on it) causes problems.
There is a good write-up about SPF roofs here: http://www.ncfi.com/EDU_Article.htm
and about 1/4 way down this page, very good coverage of the different coatings: http://www.wbdg.org/design/env_roofing.php
Regards
Gerry
Gerry,
Those pictures are the craziest I’ve ever seen…what the hell is with the rock…:shock:
I can just see the AC walking to each unit and pushing the stone right to the sheathing…unreal…:shock:
Of all the Foam roof coating I have inspected here, never have I seen ballast…:roll:
Hi Dale,
I agree mate, I shake my head every time I see it (on average once a week this year) I can’t believe it’s approved by the foam manufacturers but it is, the argument is that it is much cheaper than an elastomeric coating, and requires less maintenance, however an elastomeric coating seals the foam reducing it’s off-gassing rated (thus maintaining it’s thickness for insulation) also it provides a good moisture barrier (the foam itself is not totally water proof) moisture vapors will tend to be drawn through the roof deck in areas that are normally cooled, like Florida :shock: :shock:
Personally I hate to see the ballasted system, especially down here where that covering will become someones debris field during a high wind event, the last picture I posted was of a new SPF roof with an elastomeric coating onto which a fine aggregate had been applied while the coating was still wet, those particular roofs were very well done and very consistent (probably machine Applied rather than hand sprayed)
Regards
Gerry
Thanks Gerry ;
and I agree with Dale, Ballast does not make sence other than adding this 10 lbs. per sq. ft. to the structure design. Crushed rock, Wow. :roll: Like installing sand paper with a 0 grit’ on a ballon membrane. ha. ha.
I will stick to the reqular fully adhered membrane. ha. ha.
Marcel
Hi to all,
Here’s a few more images for you delight and delectation
From left to right:
- Blistering
- Scouring of the aggregate
- Hole formed by blistering (probably caused by poor surface preperation when re-coated or repaired)
- Savagely attached by Palm tree!!
Regards
Gerry
Gerry,
You need to be more carefull how you walk on these roofs during your inspection. Blowing up these cute air pockets is not amusing to the seller.
Inspections are suppose to be non-destructive.
Marcel
:mrgreen:
Gerry;
Thanks
If I did not see the worn areas Gerry I would have sworn that was not a foam roof.
Hi to all,
I hear you Brian, when the stuff is machine applied it can go down very evenly, I am guessing that your second picture was caused by the machine not tracking properly along the previously laid down material, and the 3rd image is of a void in the roof, the last image looks like some small patch repairs (probably done immediately after the covering had been applied).
Regards
Gerry
In florida we have the luxury of 12 days a year when the manufacture’s criteria for appplication of this product can be fully met with respect to temperature and humidity. How the hell did we get so many of these roofs? Also what I have read would indicate that every one of those ballasted(rocks applied) roofs should be sealcoated too with elastomeric. Great example of a bad Idea which has really done well.
Do I detect a note of cynicism there Brian ?? ![]()
I agree ![]()
Regards
Gerry
Good guesses Gerry, third picture is supposed to be a plumbing vent. ![]()
Now that is funny Brian.
After I looked at that picture again, I have to agree with you, but give Gerry a break hear. ![]()
Was the picture taken while the vent was being installed?
Vent location to be?
Someone pulled the vent out while you were there.
Or are you pulling our legs?:mrgreen:
Marcel
OOOOOpps, I guess they left it a little short Brian :shock: too funny :mrgreen:
Regards
Gerry
Great information. I really appreciate it. I will be out on a 24000 sq ft roof today. I will post pictures later for your enjoyment.
Does anybody out there know what the mininum thickness to apply the foam is? Roof in question is standing seam and for the majority it had 1/4 to 1/2" of foam applied. From what I have read a one inch is mininum.
