FPE Panel
Originally Posted By: pcarter
http://www.nachi.org/bbsystem/usrimages/E/Electrical_Distribution_Panel_-FPE.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/E/Electrical_Distribution_Panel
-FPE_-_and_Main_Disconnect.JPG ]
Patrick C.
Town & Country Home Inspection Services, LLC
(Serving S.E. Kansas, Cruising the 169)
Originally Posted By: rharrington
Patrick,
Is that a shelf right under the panel? Wonder if the panel was blocked when the residence was occupied?
Thanks
Rick
Rick A. Harrington
Central Ohio Home Inspections
www.patchhomeinspections.com
Quote:
So Joe T. if you still need one, I can possibly get this one when its been replaced. Let me know and I will try to arrange to get it for you. A side note, the lender asked that it be replaced too after reading the report. I also put in my report the two links found here regarding the safety issues with FPE Stab-lok. Below are pictures of the panel.
Thanks, thaat would be appreciated!
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
Rick,
I suspect it was blocked, the panel was in the pantry behind the kitchen. There were tale-tale signs that items were stored on the shelf. I put an information note in the writeup regarding the importance of keeping the electrical panel access clear.
Joe T.
The buyer closes on the home tentatively on July 27th. I have asked her to let me know when they are scheduling the new installation, they are also going to re-wire the home, no grounds on outlets, fixtures and appliances. This was an home looking for an accident. I will let you know as soon as I know.
Patrick C.
Originally Posted By: rwashington
Those FPE’s are something. I had an early 80’s home Sat. that had two FPE’s. Not one main and one sub. Actually two main panels. The 70 amp AC breaker should have been on a 40 amp max and three or four breakers came right off the housing when I tripped them. Scary…
Richard W Washington
www.rwhomeinspections.com
