Originally Posted By: evandeven This post was automatically imported from our archived forum.
Here is a garage door opener that is wired with an extension cord. Sears, who installed this motor, uses this method quite often. The connection between the motor plug and the extension cord is right at the attic access.
-- Eric Van De Ven
Owner/Inspector
Magnum Inspections Inc.
I get paid to be suspicious when there is nothing to be suspicious about!
www.magnuminspections.com
Joe, You are correct about my feelings about Sears. I once got into a heated argument with one of their “head installers” about the poor installation on another home. A licensed electrician came out and installed the proper outlet and then the homeowner billed Sears. Sears sent them a check after the electrician wrote a letter stating that it was an unsafe installation and they would have been held liable for any damages.
On the house that we are referring to, the attic hatch is right there, the sub panel is right in the garage at the rear wall, there were plenty of spaces for a new breaker and a "pop-in type electric box is fairly inexpensive. The whole job cost about $125.00 for an electrician to do it. On the picture of my garage door opener that is wired to the light fixture, I will fix that one day! I actually have the parts to do it, just a little lazy!
– Eric Van De Ven
Owner/Inspector
Originally Posted By: rray This post was automatically imported from our archived forum.
I don’t have a problem with this, and neither does my local AHJ, as long as it is done properly. See my post under “Great Electrician.” “Fastened in place” in the NEC seems to be the key according to my local AHJ. Check with your own local AHJ to see if additional requirements or restrictions apply.
