Hello,
I was curious if a gas line ran to the exterior for a gas grill was required to have a shut off valve at the stub out?
Every other house I’ve inspected there is usually a shut off at the wall.
House was built in 2020 - State Arkansas
You’d need to consult the codes for your area to know what is required. In the picture you supplied the valve would be installed when the line was connected to the grill. A capped gas line does not require a valve.
