Are gas log fireplaces required to have glass door installed? Thanks for the help.
Depends upon the Fireplace unit and the type of gas log installed.
Some are required not to have a glass door while others are required to have a permanently fixed panel.
The vented gas logs must have a glass front or door…and also a damper lock to keep the damper from being accidentally closed…the un-vented gas logs are not allowed to have doors because of sooting…as i understand it…
Thank you!
Related links.
http://www.majesticproducts.com/content/support/manuals.cfm?browse=category
Majestic Fire Place
http://www.hargrovegaslogs.com/inst/BBNG.pdf
Gas Fire Place Instructions
