Originally Posted By: kbaldwin This post was automatically imported from our archived forum.
Hi all, I’m considering installing Hardi-plank siding over my existing T-111 siding. I was wondering if anyone had experience working with this product, and could give some tips/hints. Please don’t point me to the website, I already know where that is. What I’m looking for is real-life tips, such as types of nails, should I use nail gun, cutting tips, do I need special blade, things to be avoid, etc. Thanks!!!
Originally Posted By: mcyr This post was automatically imported from our archived forum.
Keith; I agree with Tim that that video is worth it. I personally watched all 15 of them this morning.
Take a look. It takes about 3 hours to go throughout all fifteen.
Since Hardy Plank is also a sponsor, they elaborate on their product.
Originally Posted By: dedwards This post was automatically imported from our archived forum.
Keith,
I have some experience with Hardi plank. Definately use a nail gun as it will make the work go much faster, use a galvanized nail. Also recommend getting the clips to help hold the planks in perfect alignment while nailing. I highly recommend getting the electric shears to cut the planks as there is virtually no dust as with the Hardi friendly circular saw blades. The shears have a slight learning curve so practice on a scrap piece a few times before attempting to get into the real work. When nailing with the gun don’t get too close to the edge can it can break off but it is rare if a little care is taken. Most of the nails will be at the top of the course and under the bottom of the next course (blind nailing). The corner trim pieces are also Hardi material and match the planks for an almost maintenance free product. Unlike wood there are rarely any blemishes so you get consistant quality if you take a little time and care. They now have Hardi Soffits as well if you are inclined. I helped my sister and her husband build their home (still am) and they did it all in Hardi plus I have used it before for my own home to replace LP siding. Great stuff and impervious to water damage. If you have any questions feel free to email me or call me privately. Hope this helps. To find the shears go into Google and plug in Hardi Shears. I found a set online for them and saved them about $60.
Originally Posted By: dspencer This post was automatically imported from our archived forum.
Use a air powered roffing gun and make sure you get a hardi-plank saw blade. Do not forget to flash behind each seam. Measure twice cut once. I use a laser lever line to start and then make a reveal gage to place the rest. Nail 16 OC. Get a helper; stuff is heavy.
Originally Posted By: jborkowski This post was automatically imported from our archived forum.
kbaldwin wrote:
Hi all, I'm considering installing Hardi-plank siding over my existing T-111 siding. I was wondering if anyone had experience working with this product, and could give some tips/hints. Please don't point me to the website, I already know where that is. What I'm looking for is real-life tips, such as types of nails, should I use nail gun, cutting tips, do I need special blade, things to be avoid, etc. Thanks!!!
KB
Hello
I would get in contact with the local area rep from James Hardi. They will be a great help to you or your installer. I just did my house in Hardi-plank & shingle siding and it is dynamite.. The local rep Nelson Conarroe for the New Jersey Shore area very informative. His number if you wish to call him to get a name for your territory is 201-521-2061. Good luck
Keith,
No, they are something you can buy. I wrote down the name of the panel clips and the phone number when I was up there helping yesterday but can’t find the piece of paper. I will be up there helping them install some new cabinets tomorrow so I will get them again for you. I figured you would need the name / number to find them. They clip right onto the edge of the Hardi plank then they have a slot that slides onto the previously installed course. This frees up your hands to do the nailing plus it aligns the planks up perfectly. It makes the job go much quicker. I will get them for you tomorrow.
Keith,
The name of the siding clips is “Gecko Gauge”. They are made by the same folks that makes one of the siding shears that cuts through the Hardi planks so easily. The name of them is Steelhead , Model No. SS-404. All of this can be found on their website:
