Originally Posted By: jonofrey
http://www.nachi.org/bbsystem/usrimages/D/DSC05825.JPG ]
Inspection Nirvana!
We're NACHI. Get over it.
Inspection Nirvana!
Originally Posted By: rcloyd
Russell G. Cloyd
Intra-Spec Home Inspections
& Code Consulting, LLC
859-586-4591
www.intra-spechomeinspections.com
Originally Posted By: escanlan
Quote: |
2406.3 Hazardous locations.
7. Glazing in an individual fixed or operable panel, other than in those locations described in preceding Items 5 and 6, which meets all of the following conditions: 7.1. Exposed area of an individual pane greater than 9 square feet (0.84 m2); 7.2. Exposed bottom edge less than 18 inches (457 mm) above the floor; 7.3. Exposed top edge greater than 36 inches (914 mm) above the floor; and 7.4. One or more walking surface(s) within 36 inches (914 mm) horizontally of the plane of the glazing. Exception: Safety glazing for Item 7 is not required for the following installations: 1. A protective bar 11/2 inches (38 mm) or more in height, capable of withstanding a horizontal load of 50 pounds plf (730 N/m) without contacting the glass, is installed on the accessible sides of the glazing 34 inches to 38 inches (864 mm to 965 mm) above the floor. 2. The outboard pane in insulating glass units or multiple glazing where the bottom exposed edge of the glass is 25 feet (7620 mm) or more above any grade, roof, walking surface or other horizontal or sloped (within 45 degrees of horizontal) (0.78 rad) surface adjacent to the glass exterior. |
Quote: |
SECTION 2403
GENERAL REQUIREMENTS FOR GLASS 2403.1 Identification. Each pane shall bear the manufacturer?s label designating the type and thickness of the glass or glazing material. The identification shall not be omitted unless approved and an affidavit is furnished by the glazing contractor certifying that each light is glazed in accordance with approved construction documents that comply with the provisions of this chapter. Safety glazing shall be identified in accordance with Section 2406.2. Each pane of tempered glass, except tempered spandrel glass, shall be permanently identified by the manufacturer. The identification label shall be acid etched, sand blasted, ceramic fired, embossed or shall be of a type that once applied cannot be removed without being destroyed. Tempered spandrel glass shall be provided with a removable paper marking by the manufacturer. |
Originally Posted By: gbeaumont
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
Inspection Nirvana!
Originally Posted By: pdacey
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
www.southwestinspections.com
Inspection Nirvana!
Originally Posted By: mboyett
Mike Boyett
Capital City Inspections
Austin, Tx
www.capcityinspections.com
Inspection Nirvana!
