Heat pump/(a/c) unit identification
Hello everyone,
I recently purchased a house with a Carrier heat pump/ (a/c) unit. Right now it is currently not working or it trips the breaker in the house immediately as I am told by the inspector of the house. Anyway I am just curious about some information on the unit such as what year it was built is it a good model unit or how many btu’s it is etc. Basically some literature on it. I checked carriers website with no results. (maybe its a dinosaur)
I have attached a photo of the label on the unit itself.
http://i64.photobucket.com/albums/h200/1QWK96GT/CarrierUnit_zps72962e4e.jpg
Thanks for any information guys it is greatly appreciated.
:smiley:
3 ton
1997
Just curious if this is correct, I thought I read that it was March of 2001 unit as indicated by the production on the tag and that it was 2 ton with a 11.5 Seer. Just curious how you got 1997 3ton?
The sticker in your photo is for a 3 ton condensing unit, dated 1997.
Maybe the air handler or FAU is different and that’s where you read those numbers.
http://www.buildingcenter.org/carrier
That is from the information on the data plate you provided , as someone else mentioned perhaps the inside unit is different
Didn’t your inspector tell you when it was manufactured?
I think this is a test…
of the national broadcast system ?
I think you are correct I smell a fish:roll:
No that’s Chicken…
oops, that’s from my kitchen!
Hahaha you guys crack me up. No the inspector was of the HUD home before the house was listed. I was not present for the inspection. In the report I read “HVAC problem breaker trips immediately”. I wanted to get information on the unit so I am inquiring. I had found a user manual for a 38ykc and it was copyrighted in 2001 and I saw the -------301-------- on the unit so I though march of 2001. Guess I was wrong. Thanks for you help guys.
