Most of the home inspection schools in the world are now using InterNACHI’s curriculums, course materials, online resources, and inspection textbooks. The schools are also asking for paper, mock inspection, reporting forms to train their students on. We’ve come up with one (based on InterNACHI’s residential Standards of Practice):
We are seeking comments from veteran inspectors.
As always, plenty of door prizes will be shipped to the members who constructively contribute to this project.
it would be great if I could give an answer like this see below
[FONT=Cambria-Bold][size=5]ROOF[/size][/FONT]
I
inspected
from
ground
level
or
the
eaves
the
roof–‐covering
materials. . . Used 25 power scope and roof some immediate repair loose shingles some broken .
The
roof–‐covering
materials
were
not
inspected,
because
they
were:
inaccessible Snow covered
unsafe Snow covered
not
present
not
within
the
scope
of
the
inspection
I
inspected
from
ground
level
or
the
eaves
the
gutters.
The
gutters
were
not
inspected,
because
they
were:
inaccessible Three stories home
unsafe
not
present
not
within
the
scope
of
the
inspection
I
inspected
from
ground .and could see some weeds ? trees growing They should be cleaned soon as possible .
I inspected the vegetation, visible indications of past surface drainage that were present, retaining walls and grading of the property, where they may adversely affect the structure due to moisture intrusion.
This is what we’re looking for – the common defects that you find, or the conditions that inhibit/prohibit the inspector from fully assessing the system or component.
Please give us more of these types of conditions, folks, so that we can add more specific checkbox items.
Also, is there any value in adding boxes so that you can check off items that are OK? I would think that homeowners would want this info, too.
I think there should be a spot to indicate whether or not the roof was walked on. I realize it is not required, but I also know that many, many inspectors do walk the roofs.
Also, weather conditions should be included, snow covered, freezing temperature, high winds, etc.
Overall I think it is a good reference to have a copy of on site and double check before you leave the site to confirm you covered all the inspection points on the SOP. I am not sure I would want to carry around a 22 page document with me during the inspection though. If thats what this is designed for, I would recommend a little box at the top to put in property address, inspection conditions, ect.
