Hey folks. Would someone look at the charger with their Fluke TiR or TiR1 and let me know the output of the charger. I have misplaced my charger and want to see if one of the many I have will be usable. Thanks
TiR Charger
Model: HK-HP-A15
PRI: 100-240V 50/60 Hz 0.8A
SEC: 15V - 0-2.0A (Set at 2.0A)
Thanks Andrew
Problem solved. Radio shack offers an Enercell charger at 15V. Amperage splis the range but it charges the unit just fine. Cost under $30 instead of over 100 for OEM.
My adapter bit the dust and I was quoted $160 plus shipping for a new one. I tried all over town and had no luck. Finally I tried my laptop charger an it worked. Just in time. The problem is that it is over powered so I don’t dare leave it plugged in too long. I am still looking for the charger so if anyone has one I’m interested. Any other thoughts that may be helpful would be appreciated.
OEM is ridiculous for these things, no matter the manufacturer. As dbelmont said, take your old one to radio shack. You can also find this information, usually, in the owners manual of the camera. If you still do not have your owners manual drop me an email and I will get you an electronic one.
Jason Kaylor
AC Tool Supply
Net Zero Tools
877-207-1244
jason@netzerotools.com
I tried radio shack and several other electronics stores with no results. I might have the manual but it must be filed away.
The charger is
Model: HK-HP-A15
I imagine there is something simple wrong with the charger such as a burnt diode but its beyond my expertise.
Aulden,
Try these guys:
http://www.parts-express.com/cat/ac-dc-power-adapters/1463
Or these guys:
http://www.mcmelectronics.com/browse/AC-Adapters/0000000301
Jason Kaylor
AC Tool Supply
Net Zero Tools
877-207-1244
