Said many times, there are some real good home inspectors but it’s these incompetent supposed-repair solutions for leaky basements and bowed in walls that kill me, and certainly doesn’t help those homeowners nor us honest contractors
1:40 mark, one can see some of the cracks, EXT cracks in these walls man sheesh and lolol an interior drainage system and sump pump previously installed $$$. Those idiots should have told homeowner exterior waterproofing was needed, NOT an INT system, same old crap man.
late in video 8:24 mark , why does this home inspector give repair SOLUTIONS? His repair solutions will NOT repair squat!!!
2:20 visible cracks and wall is bowed in a bit
2:45 see the basement floor, the 18" or so of perimeter = INT drainage system installed that did not do anything in reducing lateral soil pressure or possibly underground tree roots off the ext of walls and never stopped the water that is getting in through multiple ext cracks in block walls = SCAM
6:10 another great idea eh, slapping tar along patio–house perimeter = more incompetence
7:40 1 of the multiple ext cracks, so just leave all the ext cracks OPEN huh and leave the soil pressure, roots against the walls eh? = incompetent, shouldn’t be making any supposed repair solutions, no way
the homeowners or previous owner was already screwed, lied to by the INT system company, now this guy gonna steer them down moron-holiday-road
8:24 again his supposed repair solutions lolollll
8:34 can see at least 1 vertical crack crawl wall, likely more on exterior, the usual
Hey, removing the patio slab is NOT a solution
Grading is NOT a solution
longer downspouts are NOT solutions to the EXISTING problems here
you aren’t going to keep all water away from, off-of the full depth of these basement walls, NOT gonna happen man. Will sloping the stinking grade and longer downspouts help keep some water away? Duh! On longer heavier rains that soil is still gonna get wet, saturated and ACT UPON the wall where there are already multiple ext cracks in walls and at least 1 wall bowed in
Leaky basements, waterproofing, bowed in walls, mold efflorescence etc is NOT easily explained in a few short azz’d paragraphs, sry… Maybe it’s your short wimpy attention span that gets in the way, EH?
Christie Dear, call Uncle Bubba thank you
Christie needs help
