Home Safety report comments
Originally Posted By: dfrend
As part of NACHI’s Safe House Campaign I am starting a thread for submission of Safety related comments. The comments are intende only to raise the safety awareness of clients and are not specifically for defects. Use as many as you wish and submit any you might use and don’t mind others using. Some of the ones I will use will be from our soon to be announced partner.
Daniel R Frend
www.nachifoundation.org
The Home Inspector Store
www.homeinspectorstore.com
1st on my list is that the homeowners have no idea how to turn off the electric, gas, or water in case of an emergency.
That is something I show them all how to do.
Mike P.
Originally Posted By: Chris Norman
Good one Mike. That is an extra added bonus, a great service, good for the customer (amazing how many people don’t know), and only takes a few minutes.
Sets you apart from all the others!!!! ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Am adding it to my routine, thanks for the idea!
Chris
An example of something you could put in your report:
Quote:
Residential fire sprinkler systems are affordable. According to the Home Fire Sprinkler Coalition (HFSC), sprinklers add about 1-1.5% to the overall cost of new construction for a system that can save your loved ones and irreplaceable family treasures. That's often less money than you would pay to upgrade your kitchen cabinets or carpeting. The cost of installation is higher when installing sprinklers as part of a renovation project.
This is an easy way to suggest they invest in the system especially if it is a new construction still being built
Daniel R Frend
Recommend that they install ALL new smoke/CO/gas detectors is ALL the locations recommended by current safety standards.
And if possible, interconnect and hardwire them ... particularly the ones in every bedroom. Sometimes a single detector in a hallway can't be heard in a bedroom if the door is closed and the person sleeps soundly.
Just my 2-nickles
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
From the CPSC. Consider adding this to reports!
Quote:
The 1999 edition of the National Electrical Code, the model code for electrical wiring adopted by many local jurisdictions, requires AFCIs for receptacle outlets in bedrooms, effective January 1, 2002. Although the requirement is limited to only certain circuits in new residential construction, AFCIs should be considered for added protection in other
circuits and for existing homes as well. Older homes with aging and deteriorating wiring systems can especially benefit from the added protection of AFCIs. AFCIs should also be considered whenever adding or upgrading a panel box while using existing branch circuit conductors.
Daniel R Frend
Here is one for electrical safety. Thanks to Joe Tedesco.
Quote:
"Our visual inspection has revealed that several rooms may not have an adequate amount of receptacle outlets to be used for supplying electrical equipment, such as lamps or appliances. We recommend that a qualified electrician review the current spacing between outlets and verify compliance with any rules enforced in this jurisdiction. We also recommend that use of any extension cords be limited to temporary use and they should not be run in traffic areas, as they are likely to get damaged which may be the cause of a serious accident."
Daniel R Frend
Quote:
Smoke alarms should be tested on a monthly basis, and the batteries replaced (regardless of age) at least yearly. Smoke alarms are your families first line of defense in case of a fire. If, you have children in the home,YOUR COMPANY HERE recommends testing the smoke alarms while they are sleeping to gauge their reaction. If they do not awaken, please draft a plan to awaken them incase of an emergency. YOUR COMPANY HERE recommends that you take a few moments to prepare a fire escape plan for your home. YOUR COMPANY HERE also recommends adding smoke alarms in every stairway and every bedroom.
You can visit http://www.usfa.fema.gov/downloads/pyfff/ to learn more about fire safety and escape plans. Also visit http://www.usfa.fema.gov/public/hfs/pubs/hfs_pubs.shtm for publications on fire safety for your family and friends. YOUR COMPANY HERE is concerned for your families safety and hopes that you will follow these simple steps to protect your family in case of a fire.
Daniel R Frend
Quote:
There does not appear to be an anti-tip bracket installed behind the range, or the bracket is not installed correctly. This bracket is supplied by most manufacturers and can be easily installed at minimal cost. The bracket is designed to prevent accidental tipping of the range, which has been known to cause serious injury, especially to children. As a safety concern for your family, YOUR COMPANY HERE recommends having a bracket installed by a qualified technician.
You can learn more about these brackets by visiting http://www.michaelholigan.com/Departments/HowTo/HowToPage.asp?ts_id=ath001.
Daniel R Frend
