and apparently 2 realtors never said, saw anything either, yeppers, same morons at play n lying… more often as most you know it’s sellers but C’MON, zip from HI and realtors… are they walking around in La La land with eyes closed? Must be in these basements.
2 leaky areas close to one another, BEAM and control joint crack
…and ya know the inside system drainage dorks said, right? and would cost much more $$$ to divert the water with an INT system, and it would only hide the water that would continue to enter
i’ll give most HI’s this about the BEAM, they likely wouldn’t have noticed it but should have noticed water stains there, my problem with this HI here is they should have noticed n wrote up that control joint crack, should have n could have WARNED the buyer that it’ll likely leak and cost around $1,500-2,000 to properly fix… one can easily tell the C joint crack was doctored on the inside, hello!
