This thread is dedicated exclusively for those students currently enrolled in the InterNACHI course titled, “How to Inspect the Exterior” located at How to Inspect the Exterior Course - InterNACHI
Thank you.
Thank you.
Hi Ben,
A really good course.
Just thought you may like to know that I built custom homes (log and conventional) and additions for some 22 years. I also spent 4 years a a contractor services rep. at a large building centre.
I really wanted ot send you a message regarding PWF basements. I have built 4 PWF’s myself and designed my son’s new 2500 sq. ft. two storey house’s PWF. We have thousands of them here in Canada and we even have a CSA standard devoted to them.
I advised on an addition to a log home last year. The original home was built in the early 1980’s. I was called to look at the exisiting PWF and confirm that it didn’t need replacing. Wow, other than some scuff marks and dirt all the visible sheathing look shockingly good. No repair was needed.
Just a couple of comments. We build them with a concrete footing with PVC horizontal pies through the footings 4 to 6 feet appart. 8 to 10 inches of cruch stone with 6 mil poly over it. the base grade is toward a sump well.
Outside we use perforated Big “O” with crush over it. The PWF ply is on a 2 X8 stud wall (we can backfill it to 7 feet) and we can put up to R-28 of Roxul insulation into it. (Roxul is a super Canadian product. It has one of the highest R values for any batt insulation, is fireproof and water proof. If you don’t know the product google “roxul”.)
Black foundation coating x 2, 6 mil poly and superseal drain board finish it.
We stand the walls up, bolt them down with galvanized anchor bolts and put the floor on. Then we put on a screed board around the wall, install the sump well and pour the floor and a couple of days later backfill. Awesome basement with a 60 year warranty on materials that can be built in the pouring rain.
Have a look at this Canadian site. http://www.canply.org/english/products/pwf.htm
Thanks again for another great course.
Ed Turner - NACHI10112702
Did you any see any in your area without the concrete footing?
All I worked on or built myself, we just used the compacted crushed stone base (Minimum 5" base) over which we placed and leveled a treated footing plate- 2"x8" for 6" thick wall or 2"x10" for 8" thick wall. We then built and stood up the foundation walls on the footing plates.
I must have missed the EPS definition somewhere with reference to EIFS cladding.
What does EPS stand for?
Thanks.
Good question.
The following has been added to the course:
**Polystyrene **
Polystyrene is a polymer, and one of the most widely used plastics. Solid polystyrene is used, for example, in disposable cutlery, plastic models, CD and DVD cases, and smoke detector housings. Products made from foamed polystyrene are nearly ubiquitous, for example packing materials, insulation, and foam drink cups.
EPS
Expanded polystyrene (EPS) is a rigid and tough, closed-cell foam. It is usually white and made of pre-expanded polystyrene beads. Familiar uses include molded sheets for building insulation and packing material (“peanuts”) for cushioning fragile items inside boxes.
XPS
Extruded polystyrene foam (XPS) is a closed-cell foam. Styrofoam is a trademarked name for XPS; however, it is often also used in the United States as a generic name for all polystyrene foams.
Review inspecting the Exterior
Getting ready to get started on this “How to inspect the exterior” course and I am pretty sure I should keep in mind components that I learned in previous courses (foundations, structural components, etc) as any problems with them may very well be visually present during my exterior inspection.
Here goes!
Section 39.5 GFCI Protection for Exterior was changed with the adoption of NEC 2008. The only exception now is for a dedicated branch circuit for electric snow melting or deicing equipment. Reference 210.8 (A) (3)
Hi Dear Fellow People
Anybody can tell me what stands for EIFS?
OK…Time for the meat & potatoes
Starting course
thank you
Here we go
look forward to this one
Half way through
I’m not getting thé Number of through bolts/ lag screws to support deck ledgers Formula. I’m forgetting a part of thé equation
Thanks
Ready for the test. Great overall course, great comment on PWF also very informative as run into them a lot. Hear we go!
last but not least
very informative course, time for the exam
