Originally Posted By: wcottrell This post was automatically imported from our archived forum.
John called it right, typical test rig used by plumber for water lines. Guage does not have enough divisions for proper gas line testing, well at least in SC it does not.
Originally Posted By: Kyle Kubs This post was automatically imported from our archived forum.
It’s used for the plumbing inspection to pressurize the system with air to check for leaks. Here in New Jersey the system has to hold the same pressure over night. The rig should have been removed after passing inspection and capped.
Kyle Kubs
Benchmark Home Inspection Services
North NJ
-- Those that say it cannot be done should stop interupting those of us who are hard at work, doing it...
Originally Posted By: pdickerson This post was automatically imported from our archived forum.
I have been helping a friend build a studio at his place. The heating contractor on the job left an identical rig to this on the gas line 5 months ago when the rough-in got inspected. It’s still there, and it still holds pressure. Yes, the schrader valve is there to relieve the pressure. All the plumbers in this area use these things when the pipes are inspected by the county.
