Gaslite
Originally Posted By: rray
Anyone run into this stuff? It was labeled “Gaslite” (registered) and “5 psi” and was being used as the gas line. It was pretty cool stuff, probably cousins to PEX.
![](upload://lr3P6OtXMkWb30K4NZ6rBgfiNAu.jpeg)
Home inspections. . . .
One home at a time.
Originally Posted By: gbeaumont
Hi Russel, I see alot of this brand here in New England, indeed it is my own plumbers weapon of choice for gas lines due to its ease of use and low instalation cost.
Gerry Beaumont
NACHI Education Committee
e-mail : [email protected]
NACHI phone 484-429-5466
Inspection Depot Education
[email protected]
"Education is a journey, not a destination"
Originally Posted By: nlewis
Russel,
It is actually called Gastite. It is flexible stainless steel. It can be run through floors and walls without a sleeve. It is becoming more common in these parts as more plumbers get certified for it.
www.gastite.com
Originally Posted By: jmyers
Russel,
Yep, pretty common around here too. I find it mostly in new construction around here but I also run into some retrofit. I happen to like it since you don't have to worry about dozens of elbows, t's, taps or connectors to check for leaks. I have only ever found one connection that was leaking at the manifold, the rest have been good.
Joe Myers
I’ve been reading about it thanks to the links provided above and the fact that I now have the name right. It seems to be pretty impressive stuff. No wonder the plumbers’ union didn’t want it in California and that it took a judge’s order to let it into California.
One home at a time.
