I'm Selling Crawlspace Creepers - Check em Out!
Hello everyone, I’ve designed a Crawlspace Creeper called the Crawlspace Ace. I built it out of necessity being an inspector myself and there wasn’t anything else available. I built it stronger and assemble each one personally and ship them out. The creeper allows you to roll through the crawlspace instead of sliding on your stomach and legs. A lot of work and time and material costs. Please check it out and purchase one if it interests you. Use coupon code interNachi471 to receive a $50.00 discount for interNachi members only. Stock is limited now but I’m assembling many more to come.
Any questions please contact me. Thank you
https://www.crawlspacecreeper.com/
Hope you did your due diligence at the Patent office, as there are many others already out there (for at least a few years) that look almost identical to your design!!
Nice, David!
Good luck with your creeper sales. :+1:
Welcome to our forum, David!..enjoy participating. :smiley:
Thank you Larry, truly appreciated.
Needs to be 6 inches wider with a dip or cut out in the middle for my fat belly to fit.
New way to pound your d*** in the dirt.
I make a 16.5 wide model also. I’m 6-8 and about 285 pounds so it works.
No without the Crawlspace Ace is the way to re pound it every crawlspace ongoing. :laughing:
At 6’ 8" 285 lbs, I would invest in a robot crawler. But I understand your point for support.
How much is the 5hp motor upgrade?
A lot of pest inspectors will want this tool also. No robot for them, they have to go in and inspect plus do repairs. Robot is useless when you have to do repairs
This resembles the Krawler from about two years ago.
Creeper
Go for it! Hope you do well.
Thank you Thomas, I really appreciate that.
@dsheffer2 - If you want to sell some of these (and hope you do) you should make a demo video of it in use. All of my WA crawls are vapor barrier on soil, and I just do not see how that would work. Especially with uneven terrain, rocks, etc.
Yes I plan on doing that soon. Obviously there will be crawlspaces that you can’t crawl due to rocks or other circumstances but most you can. I know in my area it’s a huge advantage to have a Crawlspace Ace. Not only for home but pest inspectors too. This crawlspace tool will also work good for plumbers and contractors. If you’re dealing with uneven surfaces with a vapor barrier in your area that could be an issue. When you can use the Crawlspace Ace it’s definitely worth it and the perfect tool for your inspection tool bag…
Best of luck David !!
