Here is an example of the wild claims some of these companies make:
Yes the temperature of the discharge air is the same at the lower watt setting BUT so is the cu. ft. per minutes that is delivered to the room so there is absolutely no “Savings”.
Who cares!
Apparently you do KEVIN.
I did not set out to attack you in this thread but you stepped in it when you made false statements.:roll:
Quote:
Originally Posted by rcooke http://nachi.cachefly.net/forum/images/2006/buttons/viewpost.gif
Yes Some are noisy some take up less space some cost less But 1,500 is !,500 , A few years ago Consumer report compaired many different designs . Still the results are the same …
Thanks Jim . Love the last section .
Beers said the expensive heaters that Brennan and Acker’s father bought produce no more heat than a $30 space heater you can find at any hardware store.
**“If it sounds too good to be true, it is,” Beers said. **
**“A space heater is a space heater is a space heater. **
If you’re going to use one, do it safely, and don’t expect it to do miracles for your bill.”
In my state, 80% of electricity is produced fromcoal … meaning that the heat energy being generated by the burning coal is wasted. The btus going up the chimneys to produce the electricity is a total loss. Then, from the point it is produced to the point of use, much of the electricity created is lost in transmission.
By the time electricity reaches my home … almost as much energy has been used to get it there than what I will be using it for.
In this regard, electricity is the least efficient of all forms of energy which is why it is the most expensive to produce.
Many do not know that the power put into the line at the supply does not make it to the other end .
AC Suffers line loss the further you ship it the more you lose .
We in Canada have oil for sale and the USA Has turned it down .
We are now looking to sell it to China .
Next year I expect the USA will suddenly say yes .
What a strange world we live in .
Agree and Agree.
It is a no win situation to use Electric heat.
Those Amish folks would never, ever not tell the truth, would they?
These things are one of the biggest scams around. Have seen them priced at $399+ locally.
What would you say to a person who has a 22 year old home with a Pristine home finished basement that has electric Base board heat .
That is a meaningless fact. All forms of energy PRODCTION and delivery have losses. Burning abundant coal for energy is one of the true bargains. We have hundreds of years worth of coal in this country.
