Hi Joe,
I personally will not inspect trailers period but knowing that many members will, I would suggest that your first question be how old is it. Most trailers were built with a projected 20 year life span, and if the "vehicle" you are being asked to inspect is getting towards the end of it's projected lifespan you have to ask yourself if it is worth the increased liability ??
Originally Posted By: Blaine Wiley This post was automatically imported from our archived forum.
Man, Gerry....We have mobile home parks down here from the 50's. Several from the 60's, and a ton from the 70's.
We also have a new park up the road that the double wides start at $140,000. If you don't do mobile homes in my area, you throw away ? your business.
The most problematic areas on mobile homes (at least these) are the floors, roofs and many have Polybutylene plumbing lines. And termites just Looovvveee to chew em up.
Quote:
They just scare me with hidden issues that can come back quickly - Plus they are a bitch to inspect -
That is why in my agreement is a statement that "hidden, latent or concealed defects are not within the scope of this inspection".
I also have a statement in my report that explains that mobile homes due to their construction have a much greater risk of hidden defects than the average home. Something like that anyway.
Again, the roof and floor are the areas major defects are usually found, and you have to disclaim the floor most of the time because it is covered with insulation and a moisture barrier. There are almost always termite mounds in the crawl area, many have Polybutylene plumbing, Harry Homeowner for some reason almost always is the on site electrician, the walls are paneling which after 5 years is warped. But, they are still easier to inspect than Boats!
