Inspecting New Construction In Ohio
Here’s Ohio’s descrition of a Residential building.
Section 4764.01 - Ohio Revised Code | Ohio Laws
(H) “Residential building” has the same meaning as in section 3781.06 of the Revised Code but also includes the individual dwelling units within an apartment or condominium complex containing four or more dwelling units.
Section 3781.06 - Ohio Revised Code | Ohio Laws
(9) “Residential building” means a one-family, two-family, or three-family dwelling house, and any accessory structure incidental to that dwelling house. “Residential building” includes a one-family, two-family, or three-family dwelling house that is used as a model to promote the sale of a similar dwelling house. “Residential building” does not include an industrialized unit as defined by division (C)(3) of this section, a manufactured home as defined by division (C)(4) of this section, or a mobile home as defined by division (O) of section 4501.01 of the Revised Code.
Now look up what Ohio defines a dwelling house as!
DWELLING UNIT. A single unit providing complete independent living
facilities for one or more persons, including permanent provisions for living,
sleeping, eating, cooking and sanitation. The dwelling unit may include any
accessory space intended for the exclusive use of the occupants of an individual
dwelling unit such as a private garage, greenhouse, etc.
This is AFTER the C of O.
Wow does anyone here know where I can get lots of nifty certificates to upload with all my posts?
Still no answer. Just crickets and certificates!
I have around 25 that I can loan you, but they all have my name on them…
PARTICIPATION Certificates are a dime a dozen and easily found on the internet.
Print what you need!!
I replied to Kevin. Your answer is in there.
Yes, I was a student in that CE class. Please share some of your learning experiences on the code. You really think that I care what you say?
OMG that is so funny!!
Certificate1
Uh Oh seems you are on the Demi-demigod’s radar for cancellation! :rofl:
What would be fun is to see them enforce their registration mark!
If you have the proper license it is not an issue. In MS you must have a special designation on your home inspector license to inspect new construction, it is called an NH designation. I think VA requires something too. Curious what State has the cite you posted in their license law?
Ok now we have 3 states that prohibit new construction inspections unless other licenses/certifications are obtained.
There it is that simple. You can inspect whatever you want so long as you obtain the necessary credentials.
I want other inspectors to be allowed to inspect new construction. One lets change the law or 2 go get certified.
It is from New York’s HI law.
Thanxs for sharing.
Thanxs for sharing.
NC is tough on their home inspectors:
(a2) State Building Code. – If a licensee includes a deficiency in the written report of a home inspection that is stated as a violation of the North Carolina State Residential Building Code, the licensee must do all of the following:
(1) Determine the date of construction, renovation, and any subsequent installation or replacement of any system or component of the home.
(2) Determine the State Building Code in effect at the time of construction, renovation, and any subsequent installation or replacement of any system or component of the home.
(3) Conduct the home inspection using the building codes in effect at the time of the construction, renovation, and any subsequent installation or replacement of any system or component of the home
No thank you!
This is not the entire rule… This is only required if the inspector says X is not built or does not meet code, etc… It is easy to get around this and the majority of inspectors that work under this law simply say “X does not meet current or recognized building standards or the manufacturers guidelines”, the inspector never mentions “Code” and all is well.
What do you think ‘code’ is? I not saying that you can’t do something. I am saying stop fooling yourself into believing that you are not referencing code by simply not using the word.
Do you really think that argument would prevail in court? Come on.
