Interesting sink plumbing
Originally Posted By: rray
I’d like to soliciit some comments on this bathroom sink plumbing.
![](upload://vWW4L0ppXI91B5culKaL0TzONOt.jpeg)
![](upload://fpLhpwNerlAsH8pCuopiHCWZkrr.jpeg)
This was a dual-sink setup in a bathroom that was nowhere near the dishwasher. The lettering on the hose on the left in picture 1 said "dishwasher" and was your typical dishwasher drain hose. That hose led to a T-joint just past the trap. Picture 1 is the left sink. Picture 2 shows the right sink, continuing from picture 1. Notice the interesting drain pipe much higher than the traps. The draining in both sinks here was very slow. The gray plastic tubing in picture 2 was PB2110 and the water flow was very low at that sink.
Home inspections. . . .
One home at a time.
Originally Posted By: gbeaumont
Hi Russel, don’t know where to start on that one, but if the outlet was any higher we would be discussing cross conection issues icon_smile.gif
Regards
Gerry Beaumont
NACHI Education Committee
e-mail : [email protected]
NACHI phone 484-429-5466
Inspection Depot Education
[email protected]
"Education is a journey, not a destination"
Originally Posted By: dvalley
Russel,
Excellent plumbing situation.
That middle fitting in sink #2 is a Y fitting, and is facing the wrong way. All waste water coming from that higher drain will be diverted towards the P-trap and up into the main sink drain. Not good.
The plumber called in on this one is going to get a laugh. ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: jmyers
David,
So you got a little SH** in your sink, so what! ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Joe Myers
Joe,
Yeah, No biggie.
What would us Home Inspectors do without these (gonna save a little bit o' money homeowners) who rig and fix household items their own way(the cheap way).
We would be bored inspecting homes if we were finding everything to code. ![icon_cry.gif](upload://r83gSGUzNOacIqpjVReDwcR83xZ.gif)
Good Eye
David Valley
MAB Member
Originally Posted By: KipHamilton
Hey Guys…new member here…
How would you write up this situation?
Kip
Originally Posted By: jpope
Kip,
My write-up would be fairly simple;
Improper waste line/trap system. Recommend repair by licenced, qualified, plumbing contractor.
In CA (I'm not sure about other states) a permit is required to replace, repair or install a plumbing trap. ![icon_confused.gif](upload://qv5zppiN69qCk2Y6JzaFYhrff8S.gif)
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Thanks Jeff.
In MD, you're suposed to pull a permit to install a dishwasher, too.
a dollar here, a dollar there....
Kip
Anything to do with waste lines that can be improperly assembled (drain traps, air-gap devices for dishwashers, etc.) , requires a permit in CA. It makes sense if you really think about it.
Jeff Pope
“At JPI, we’ll help you look better”
(661) 212-0738
I would write this up as a “creative plumber” that should have considered taking up art, FULL TIME! icon_biggrin.gif
Joe Myers
Originally Posted By: jpeck
David “That middle fitting in sink #2 is a Y fitting”
It's a "sanitary tee", not a "wye". and yes, it is facing the wrong way.
Jerry Peck
South Florida
fitting has a branch line added at a 45 degree angle for two drains to drain laterally into a main discharge.
The "sanitary tee" is a change of direction fitting where two drains discharge into the same piping. This fitting directs the flow into the proper direction.
David Valley
MAB Member
