First post on this forum.
I saw this service panel today and I cannot see that the neutral and the ground are bonded. it looks to me like it does not have a bounded neutral. Would you agree?
Thanks!
Until you get a photo posted… NO, it is not! (Better safe than sorry).
This is what I see…
If my head wasn’t screwed on, etc…
Picture now attached
Typically a green screw will indicate the bond point, if I am understanding your question correctly.
I agree with Ryan.
From here it appears that the neutral bus is bonded to the panel via the green screw.
It looks correct from here, if that’s the main panel. Ryan pointed you in the right direction
I agree with Ryan, Kevin, and Christopher!
Thank you all very much for your help!
is this the service panel? Or a sub panel? It is only 100 amp, and if it is a subpanel, its wrong.
OP says…
