Originally Posted By: dedwards This post was automatically imported from our archived forum.
John,
Ive never seen drywall used for exterior sheathing either. In fact drywall would be my last choice of any sheathing material for this application. It is evident in your photos there is already a moisture/mold problem going before any interior walls are put in place. Very curious.
Originally Posted By: Michael D Thomas This post was automatically imported from our archived forum.
Was this building close to another structure? In some jurisdictions drywall applied to exterior walls is acceptable to provide fire-rating.
Usually though it applied over sheeting, covered with house wrap, and then sided, and a different material is used for the lower 24" or so to reduce wicking.
(I?m not saying this is a Good Idea ? just that I?ve see it done).
Originally Posted By: jstevens This post was automatically imported from our archived forum.
Hi guys
I have put siding on a lot of homes in mass , They had sheetrock on out side walls with tarpaper then alum. siding, They where not site build but built in a factory in one piece then flown in by choper and set on a slab.When we installed siding on them , We strip the alum. then put plywood on
A lot of the times we had to strip the rock off because it was so far gone
Originally Posted By: mcyr This post was automatically imported from our archived forum.
It appears that the problem exist in the movement of water vapor.
Seeing that you are in Texas, Vapor pressure will cause moisture to move through a wall by diffusion, even if their is no air pressure difference between the two sides of the wall. Vapor diffusion can even move moisture in direction of small differences in air pressure.
In hot humid climates the higher vapor pressure and temperature outside and air condition dehumidified house will cause the movement of vapor through the exterior walls by diffusion, even if the air pressure inside the home is maintained at a high level.
Airflow retarders can greatly reduce heating and cool costs.
Movement of water vapor by air transport is obvious on this problem.
15 # asphalt felt has a permeability rating of 1.0., gypsum wallboard of 3/8" has a permeability rating of 50.
In hot and humid climates wall assemblies can be protected from moisture entry from the exterior. In this case walls will dry to the interior. To accomplish this, the need of no vapor diffusion retarders is needed on the interior.
It appears that the answer to this question would be that the flow through approach was not use in the building. If permeable or semi-permeable home materials are used throughout the wall, water vapor will diffuse through the wall without accumulating.
It appears that due the construction methods used, that the moisture is held at the gypsum board exterior sheathing that is common to construction , caused by possibly a double vapor barrier. One on the outside and one on the inside. Thru vapor diffusion, the moisture is trapped on the inside of the wall assembly.
The OSB family now has ADVANTEK, it is somewhat more relaxed on water absorption. Most homes inspected today do not have that and you are correct in stating that it swells up, and the key here is to protect the product when it is being installed.
Inspection of dwellings that have been constructed with OSB and protected in the installation or covered over as soon as possible with siding etc., will prove that it is as reliable as the CDX plywood manufactured today. There is a reasonable cost differential and is also what called a Green Product.
Originally Posted By: lgoodman This post was automatically imported from our archived forum.
Every day I pass a garage that we built in the late 80’s. Owner was going to cover the OSB with vinyl siding to match the house. He never did. The new owner painted it lipstick red. It looks as good as it did when built except for that color.
I am totally opposed to vinyl siding and will not install it. This house is my nearest neighbor. For the new owner we removed the vinyl from the house, put a second story on one half and a new rafters,deck and shingles on the other half.New windows,doors and T-111 over the OSB sheathing.
When we removed the vinyl we found, as we always do, wet sheathing around the windows.
Marcel,
T-111 on my house 21 years. Uncle's house around 35 years. I am very satisfied with its performance. So are his heirs.
No holes from objects thrown by lawn mower. (maybe as many as 20 on neighbor's house when we removed vinyl -his dog carries stones) No wet spongy aea around windows. Superior resistance to wind infiltration. No buckling or oil-canning from temperature changes. Natural wood product from renewable resource. Doesn't look like a plastic house at all. Blends right in to the woods that surround me.
I don't mind new products that improve upon the old. What is the improvement offered by vinyl? I'm not being flip, I think you must have some reason for loving it and I am willing to evaluate your reasons against my total disdain for the material.
I think we are destined to meet in person someday since we meet so often here. It will be my pleasure to meet you.
Hi. Leigh, hope you are fine and business is good.
I have copied these photos about T-111, I have not had good luck with the product, and it seems it needs a lot of TLC that it usually dosen't get and the Geographic area might make a difference.
It won't let me copy and paste, so here is the address:
sidingsolutions.com/pager/sidingid.htm
This will give you more insight on the product in general.
looks to me like these pics show white and black mildew. once those 2 spore types begin to “fight” for teritory they let off a toxic gas (forget the gas name) and that is the real danger. close that in a moist dark wall and the entire household will have constant health problems, usualy writen off as “alergies”. suggest…10 parts TNT and 1 part lit match…RUN.
