Hello home inspectors.
Are joist hangers an acceptable type of hardware for connecting stair stringers to a deck?
These joist hangers are fitted into the stringers via notches that the bottom of the hangers fit into.
That is called “an ad hoc construction technique.”
Looks pretty cheesy. There are hangers made for stair stringers that wrap under and down the bottom edge of the wood. The deck screws in the hangers aren’t kosher either.
Wrong hanger for the job, this is what’s needed:
https://www.strongtie.com/deckconnectors_decks/lsc_connect/p/lsc
That sure wasn’t done by a qualified carpenter, that’s for sure. Wrong hangers and fasteners.
Good to know! Thanks, @megbert2 !
That’s helpful to see a stringer connector that should have been used. Thanks, @srechkin .
I appreciate your help, @lkage .
That’s basically what my report is going to say. Thank you, @mcyr !
This header looks interesting, too.
Yeah the header is warped. Here’s a photo of the top of the stringer, as seen while standing on the stairs:
I can’t believe nobody brought up these dangerous items.
Location, location, location.
Exactly my concern, as well.
