Are junction boxes that are in the attic that are accessible exceptable
Accessible junction boxes, in the attic or other place, are acceptable if installed properly. ![]()
Do you mean “accessible” as in no cover plate?
with a cover plate, this is not a inspection I was just curious for when I do run into this situation
Yes, but I suggest that you try to refrain from using the term “acceptable” when writing reports. What is acceptable or unacceptable is up to the buyer (or AHJ). Try to stick to terms such as defective, deficient, improper…
thanks for the advice, that makes sense what you said Chuck
