http://www.youtube.com/watch?v=TWzk9kSB4U0 ](*,)
Former salesperson of Insta Dry basement systems which is ummm, OOB.
1:00 says, ‘carbon fiber straps bonds the wall together and STOPS ALL further movement’.
…completely full of sht!
1:30 says, ‘carbon fiber straps is a very quick way and it’s a PERMANENT solution.’
…completely full of sht.
NO beams, no carbon fiber straps, no wall anchors are a permanent solution and cannot STOP ALL further movement, you are incompetent and-or just talking outta ter azz in order to drum up some more scamball business, that’s right.
Just like Insta Dry basement systems lied, cheated people…your carrying on the same old bulshtt pitches, lies…yepper.
Eh bubblehead, when part or all of the reason/problem for a basement wall to crack, leak, bow inward is due to clay and-or underground tree roots or porch footings or concrete slabs etc then…THAT is what needs to be removed, that’s what needs to be done.
And shthead,you omitted, on all these block and brick basement walls there are EXTERIOR cracks, cracked parging…on the outside of those walls, got that?
And you say all homeowners need are freaking carbon fiber straps??? ](,)](,)
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing36
Wall anchors installed, very likely told homeowners that was all that was needed.
Well dumb az, cracks have widened and it or course, still leaks!!!
That’s because YOU dumb az’z don’t understand or don’t care that there are Exxxxxxxxxxxxxxxxxterior cracks in these walls, hello!!!
First 16 pics here, beams installed…aagain nothing done on exterior which is, where the problems are!!! Fc!!
http://picasaweb.google.com/101049034584960315932/BasementWaterproofingIBeamsEtc
Clay, underground tree roots and some concrete slabs ARE the PROBLEMS.
Yet, another bubblehead sells homeowners CRAP that doen’t remove, relieve the reasons why the wall is bowing in, has multiple cracks and leaks!!! ](*,)
Here’s what underground tree roots can do to the outside and inside of a basement wall, since you fc n don’t get it!
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing09
Click each photo to ENLAGE dumb az…see the root, cracks, see the inside?
http://picasaweb.google.com/101049034584960315932/Crawlspace
Eh, eyeball the dang photos a z ho…
Wall is BOWED IN. Leaks.
Not only are there multiple exterior cracks, gaps etc but also see what happens to some blocks…
http://picasaweb.google.com/101049034584960315932/Crawlspace#5540665133328086770
Can you say disintegrated, deteriorated…huh?
So your dumbshtt carbon fiber straps do NOT fix,repair,waterproof any of this! ](*,)
Pathetic, incompetent, greedy sobs out here tell homeowners just about anything to get a job, to sell -install the CRAP they do.
And to some other incompetent az ho’s who incorrectly think and tell homeowners to raise and slope the grade, your wayyy off as well, need to be sued just like these inside system bubblehead cheats, that’s right.
