jgriffin23
(Jeff Griffin)
September 1, 2022, 7:09pm
Is this Knob and tube wiring
rbleich
(Richard Bleich)
September 1, 2022, 7:35pm
2
It looks like it could be a “knob-and-tube” neutral.
jmckee
(James McKee)
September 1, 2022, 7:36pm
4
there is also non metallic cable in that picture…
jgriffin23
(Jeff Griffin)
September 1, 2022, 7:51pm
6
Yes it was energized. Would this be Active Knob and tube
jjonas
(Jeffrey Jonas)
7
Commonly as seen in a home today that has only been partially converted to modern wiring…
dwigger
(David Wigger, CMI, Retired)
September 1, 2022, 8:06pm
8
Since it was energized I would call it active. The photo’s you posted show that it is still in the open air and has not been covered with insulation, which is good. Unfortunately, insurance companies generally frown on K & T wiring.
ruecker
(Ryan Uecker)
September 1, 2022, 8:28pm
9
Jeff Griffin:
Yes it was energized…
A note of caution, those sniffers can give false readings if another energized cable is nearby. Try and find a location to test that is far from other cables.
ddagostino
(Dominic DAgostino, CMI HI3957)
10
Jeff Griffin:
You should check it farther/further away from the NM cable, as stray electric current can be picked up by those non-contact testers.
ddagostino
September 1, 2022, 8:29pm
11
Sorry Ryan, posted at the same time.
jmckee
(James McKee)
September 1, 2022, 8:47pm
12
can’t beat the lick test ! it never fails…
ryoung7
(ROBERT YOUNG, CMI)
September 1, 2022, 11:27pm
13
James McKee:
non metallic cable
NMD-7 likely. Looks too dusty to be NMD90.
ryoung7
(ROBERT YOUNG, CMI)
September 1, 2022, 11:29pm
14
Doesn’t hurt your teeth when you wear full set dentures. Give it a try.
rlewis5
(Roy Lewis, CERTIFIED MASTER INSPECTOR)
September 1, 2022, 11:57pm
15
That isn’t single strand K&T.
They are just using the k&t’s.
