Knoxville TN Home Inspector finds hidden water damage
The chimney is an area that can be extremely suceptable to leaks due to improper construction. Other home inspectors may not find the leak because they will not look behind siding, even when the signs of potential issues are there.
Another video on hidden water damage. :smiley:
Good video Sean, it never fails when that type of installation is visible. :slight_smile:
We always recommend diverter flashing when we encounter similar situations.
3 tubes of caulk to fill in the gaps may work also.;):wink:
Seen some of that too Linas, and does work for awhile. :wink:
Never mind… see you on Google! :wink:
Maybe I shouldn’t be sharing all my secrets on the message board. :wink:
Don’t want others to catch on how I seem to stay busy.
No secret to me Sean.
Keep on doing what we should be doing. :slight_smile: :wink:
What secrets?:roll:
Putz.:slight_smile:
That’sright Sean, they aren’t secrets but I’m glad you found it.
Excellent thread title for SEO purposes BTW. Keep that up.
