I found this today. This is some type of lift or grinder pump, it discharges into the sump pump. The sump pump discharges underground, termination point is unknown, I think I know where, but not sure.
What do you GUYS, say???
Thanks, for the help
If you are saying it is a portable ejector pump then it should not connect to a sump.
Was hooked in to a toilet ?
Thanks! No, it discharges directly into the sump pump.
This is an above ground sewer ejector (that is seeping at all penetrations). The only place this ejector should be discharging to is to a main waste line, not a sump pump.
That’s nasty.
Thanks! David. I deferred it to a plumber.
This is another excellent reason not discharge the washer directly to the sump pump. The entire basement was flooded.
More pic’s
It is a Drain Pump used for grey water and it should discharge into the septic/main drain.
More info at:
http://libertypump.com/Products/Category/SubCategory/Product/?p=19&s=0&c=23
