Any idea what I’m looking at in the floor here? New construction home, never lived in and close to completion. Concrete slab foundation and a pipe in the floor I haven’t seen before.
Thanks in advance, you old hands have the best info!
Washer drain. Odd that it’s not in the wall. May still need a trap.
if that is a 2" pipe it is most likely going to be a stand pipe for the washing machine drain…
Likely a drain line for the safety overflow pan that sits under the clothes washer.
I was thinking standpipe for a drain, but then I had no way to verify the presence or absence of a trap…guess I’ll write it up as such…
Was there no drain supply at the water hookups?
I agree. I see them “roughed-in” often in new construction.
Not if it’s a 1 inch pipe…
I would not do that. Your drain for the washer is here. The pipe in the floor is just for a safety drain pan.
Can you verify That Brian?
Washer pan drain. Looks like 1-1/2” pipe.
No, I wasn’t there. I have a high degree of confidence.
I tend to lead toward the drain pan for the washer, even though I never seen one installed.
Exactly my thoughts, very common to find on a second story laundry room
Here you go, Thomas. It’s a standard install.
Standard install in areas? Like I said, I’ve never seen a drain pan under a washer here. Even on new builds. May be optional if the builder elects to do so…
Rural Georgia pan under washer ![]()
Ohisu Blue Washboard Basin for Hand Washing Clothes and Small Delicate Articles Amazon.com: Ohisu Blue Washboard Basin for Hand Washing Clothes and Small Delicate Articles : Health & Household
Things haven’t changed much here in these hills…
Gary, I agree, very common in second floor laundry rooms, I guess I failed to mention this was a first-floor laundry room, I’ll have an opportunity to return to the property this week, gonna take a closer look.
Thanks again for all the input from more seasoned inspectors!
