Leaky basement 2 areas, an interior system previously installed
Inside view of the 2 areas, chimney area had INT system installed, this area leaks a TON = good for the new carpeting etc
outside view of vertical crack under concrete patio, i saw cut the stupid concrete in order to properly waterproof the crack
tar aka roofing cement after hydraulic cement applied, backfilled with all gravel
exterior view of chimney walls, RECT-- rod holes lol, cracks, holes/openings in ledge etc
ummm can one see WHY interior systems don’t stop water from entering ext-cracks etc, huh? lolol
not one word was said or noted by HI about back wall crack, nor INT system where chimney is and some basement windows were installed upside down and so on for $800 ? Hey i’m all for good HI’s getting $$ what they deserve, no shtt but NOT this HI, nope
