Your premise, thougt process is imo wrong, so sorry. It ALWAYS has been wrong = truth.
short video by home inspector, am sure he’s a good dude, trying to help etc but man, THAT doesn’t make you right on THIS subject n when you are misinforming your clients it can hurt them aka cost 'em MONEY!
He says, settled sidewalk is a no brainer… tear out or mudjack etc, no!
Says,the neighbors retaining wall is the REAL problem, no!
Is this situation, elevated grade/driveway, retaining wall, settled walkway helping to divert some water towards lower sitting house? duh but of course!
HE says/writes caption… 'House taking on water THROUGH it’s foundation walls"
Well IF that is the case, as i’ve shown repeatedly that it IS… but duh i haven’t been to THIS house then i gotta go by what he wrote… THROUGH f walls. Too bad he didn’t take a video inside basement to show walls IF its not finished down there.
So these houses been there a long time, situation been like this quite some time… n you wanna tell neighbor to tear down retaining wall (sure it needs to be done soon anyways, i get it) and $$$$ erect a new one BASED on HI’s assumption IT… is the REAL problem? No.
Can post many examples, here’s one house, leaky basement, concrete driveway up against F wall AND concrete patio in back up against F wall AND they caulked perimeter, still leaked… see WHY
same house now DUG OUT… “THE” problems…
One POINT is, even if neighbor replaces retaining wall AND the walkway is torn out, replaced or mudjacked, when there are exterior cracks in F wall or cracked EXT parging or there was NO parging applied or there are deteriorated rod holes or openings around, under basement windows etc, the basement will still leak because water on those longer, heavier rains will still get UNDERNEATH mudjacked slabs, new driveway etc so FIND the real problems, NOT your assumptive ones and fix/repair/waterproof them.
By the dang way, NEW, newer retaining walls can… BOW IN, or, lets say new retaining wall is made of block, well… if whoever builds the dang retaining wall i bet, is NOT going to waterproof the neighbors side of that wall so… water will still get through that retaining wall at some point through the naked blocks or mortar joints that weren’t waterproofed or 1+ NEW cracks in new retaining wall can most certainly occur allowing water towards the leaky basement/house.
Look sheesh, i should be able to dig out an entire side of anyones house, WALL, or all 4 walls,all the way down to footing/drain tiles… and then FILL the entire trench with water and… IF if IF there are NO cracks in F wall, no cracked parging, no deteriorated rod holes etc then NO water will get in because… lol, there’s NO place for it to get in, whether there is a retaining wall as in video or not, whether there’s a walkway that settled or not, can ya get THIS throught hose thick skulls… huh? You claim you wanna help your clients… well HELP them g dammmmit! Get INFORMED, learn MORE, stop making BOGUS assumptions.
