Raise `n slope the grade… blah blah blah
Thats whats some recommend/tell homeowners to do AND by doing so
it SOLVES most leaky basements. ](,) ](,) ](*,)
http://picasaweb.google.com/edgesh/UncoveringThePast/photo#4990753745609031698
Hey,lookie here at PIC`s
How about the SLOPE here? Did it solve any problems or cause MORE? #-o
Want to use carbon fiber straps here and install an Inside system?
What good will either do to stop/prevent further DETERIORATION?
See, this is what ‘some’ dont understand AND, dont care about.
Well screw you, yer screwing homeowners with knothead-rookie
recommendations.
That plastic placed underground sure helped huh? Idiots! ](,) ](,) ](*,)
“As the ruble is cleared away and i start to expose areas of the building
i discover a number of things i never expected.DETERIORATION of the
underlying walls was not just limited to the primary basement wall but
was a problem all the way around the structure…”
The reinforcer, wall anchors,Inside drain tile and baseboard systems
w/sump pump doesnt stop/prevent further deterioration, doesnt
stop/lessen soil pressure-roots against a wall, doesnt waterproof the wall. Have it YOUR way, be seeing a few of yas down the road, ok? :mrgreen:
