Look what I found today...
div.jobthread-jobroll-box, div.jobthread-jobroll-box table { color: #778294; background-color: #f0f0f0; font: 11px Arial, Helvetica, Sans serif; text-align: left; } div.jobthread-jobroll-box { padding-bottom: 5px; border: 0px solid #f0f0f0; width: 155px; } div.jobthread-jobroll-box img { vertical-align: middle; border-style: none; } div.jobthread-jobroll-box a:link, div.jobthread-jobroll-box a:active, div.jobthread-jobroll-box a:visited { color: #778294; background-color: inherit; font: 11px Arial, Helvetica, Sans serif; } div.jobthread-jobroll-box a.job-link:link, div.jobthread-jobroll-box a.job-link:active, div.jobthread-jobroll-box a.job-link:visited { font-weight: bold; } div.jobthread-jobroll-box div.jobthread-jobroll-type-header { text-align: center; padding: 2px 0; font-size: 10px; } div.jobthread-jobroll-box div.line { border-top: 0px solid #f0f0f0; } div.jobthread-jobroll-box a.standard-link:link, div.jobthread-jobroll-box a.standard-link:active, div.jobthread-jobroll-box a.standard-link:visited { color: #778294; font: 11px Arial, Helvetica, Sans serif; font-size: 11px; padding-bottom: 5px; text-decoration: none; display: block; } div.jobthread-jobroll-box a.brand-link:link, div.jobthread-jobroll-box a.brand-link:active, div.jobthread-jobroll-box a.brand-link:visited { color: #778294; font: 11px Arial, Helvetica, Sans serif; font-size: 11px; font-weight: bold; text-align: center; text-decoration: none; display: block; } Is it Safe To Turn Down Your Water Heater Temperature?
by Lloyd Alter, Toronto on 03.10.09
http://www.treehugger.com/water-thermostat.jpg
Almost every checklist of energy-saving tips includes the recommendation that you turn the temperature of your water heater down from 140°F (60°C) to 120°F(49°C), including on Canada Safety Council:
In 2000, the Walkerton disaster had sent a wake-up call about the safety of Canada’s drinking water. While standards for domestic hot water must consider scald prevention, they must also address the broad spectrum of public health and safety issues. To minimize bacteria contamination, water must be stored at 60 C or higher. For example, temperatures under 50 C may increase the risk of Legionnaires’ disease, a form of pneumonia, due to bacterial growth in the tank. That disease is caused by Legionella bacteria, which live in water. Temperature is a critical factor for Legionella to grow. The risk of colonization in hot water tanks is significant between 40 and 50 C.
Legionella bacteria most often enter the lungs due to aspiration. (Aspiration means choking such that secretions in the mouth bypass the choking reflexes and enter the lung.) Drinking contaminated water is not a major cause of Legionnaire’s disease.
The Centers for Disease Control and Prevention estimates 8,000 to 18,000 Americans contract the disease annually. Five to 30 percent of the cases are fatal. While Canada has no national statistics, Hydro-Québec says about 100 people a year are hospitalized in that province for pneumonia caused by contaminated residential water heaters
](“http://www.treehugger.com/files/2009/02/does-turning-down-water-heater-make-difference.php")]("http://www.treehugger.com/food_health/”)
OK, who said anything about the house being winterized? Sounds to me the INSPECTOR had nothing to do with the winterization nor the de-winterization. So in fact the inspector had nothing to do with those conditions at all and the house was NOT winterized.
To mix up and tangle facts to make a stretch the story out to make a hypothetical case that POSSIBLE COULD happen in order to make others see a view, is well…different.
The way you put ideas out there is…well you should not run bath water. What if the shower had a hole in the drain behind the wall and the water got into the wall (Why did you turn the water handle on, it was off when you got there). Then a person with severe mold allergies moved in and the mold behind the wall made her have an asthma attack, when trying to get help she slipped on the floor and fell down the stairs and hit her head and dies…
Sticking to the facts should be point #1 and coming up with hypothetical cases can go on and on and on. If you want ZERO liability then you can never own a company. It is that simple.
Someone call somebody. We agree. :slight_smile:
Interesting article, Roy. I wonder how many inspectors will, now, be running around the world turning UP the heat on the water heaters they inspect in order to save lives. LOL
Good one Roy ! I happen to run my water heater at 140. I don’t see why not , I have to heat my house anyway . I can use less hot water with a higher temp. setting . Fail to see where there would be much difference . ;):D:D
