dandersen
                (David Andersen, TN HI# 40)
                    December 19, 2022,  5:49pm
              42
              David
A moisture meter is less accurate in detecting moisture than a thermal camera if you have adequate training.
See recent thread here about moisture meters.
Click on this link:
    I’ll try this again.
Resistance Meters (Pin Type Moisture Meters)
Commonly known as a pin moisture meter, this type used to be the most widely used meter throughout the world. Two or more pins are pushed directly into the wood in two different spots, and a direct current travels from one pin to the other. This process measures the resistance to the current between pins and correlates that resistance to wood moisture content.
Electromagnetic Field Technology, EMF (Pinless Moisture Meters)
Of…
