Originally Posted By: dgriffith This post was automatically imported from our archived forum.
Jeff, you might want to look at the service conductors. A #4 copper or # 2 aluminum would indicate a 100 amp rating or the meter might be a clue as well. A square meter base would be compatible with a 100 amp service. Look on the face of the meter as well. Use the meter as a last resort though because sometimes the power company uses an old meter in a new meter base when they upgrade service. Check the service conductor rating against the rating of the meter and meter base, if these match then you found the amperage service, if they dont match report the lesser rating because you dont want to report a 60 amp service as 100 amp. Thats a whole other issue there. Hope this helps.
– When you’re up to your a*@# in aligators, it’s hard to remember your main objective is to drain the swamp.
Originally Posted By: dedwards This post was automatically imported from our archived forum.
Jeffery,
Write it up just the way you “see” it. Everything else could indicate it is a 100 amp service but unless you know exacty what the rating on the breaker is it is called “guessing”. Sometimes it is just what it is. If you can’t find a rating marked on the device, write that in the report. Chances are very good it is a very old breaker. I have run across a few myself and I just write what I see and don’t try to figure out what someone else did some time in the past.
