Can anyone tell me what type of pipe this is? It’s the main incoming water pipe into the house.
Located in Toronto, Canada if that makes a diff.
Thanks,
I’m guessing Blue Pex piping…
What year /how old is the home
In my service area of Minnesota, that would be PEX.
Also in Minnesota, it would be required that it be protected from damage where it passes through the concrete slab.
Looks like copper pipe wrapped in a blue sleeve. Was it metal or plastic? You need to describe the material for an answer that’s anything but a guess. The trace wire indicates it’s a plastic pipe.
Looks like PEX from SWFL. PEX is the new Poly
It felt like a hard plastic.
I would identify the water service as unmarked plastic pipe.
Thanks Martin
I concur with your potable water supply pipe material hypotheses.
PLASTIC COATED BLUE COIL
Am I mistaken or is the 1/4 turn ball valve handle orientation wrong? The way the handle is setup you will not be able to close the valve. The 2x4" is in the way.
Got news for ya… (perhaps except for the ritzy, big money area Willes operates in)… there is NO municipality that is gonna spend that kind of money on a public water distribution system to every home in it’s jurisdiction!!!
Private, maybe. Public, no way in hell!
I live in South Carolina. You don’t have to go too far to see this.
Where copper pipe is GOLD!!
This mornings inspection… best I could get…
https://engage.awwa.org/PersonifyEbusiness/Bookstore/Product-Details/productId/86488411
Agree with JJ
Some of the specs PLASTIC COATED BLUE COIL
- Market Industrial
- Maximum Operating Temperature400 Degrees F
Copper(II) sulfate?
It’s plastic, a copper pipe wouldn’t need a [white] tracer wire. It’s typically a type of PE, but not PEX pipe. I would just identify it as plastic material in the report.
