Main Service panel trailer
I was on a job where the service panel was insulated behind. I felt like this was a fire hazard. What should I recommend as an alternative?
Why do you believe this is a problem? Are there some unusually high loads on the circuits that would cause the wire to overheat? Is it one of the breaker brands that are known to not trip properly?
