Metal roof and skylights
Originally Posted By: jcampbell
http://www.nachi.org/bbsystem/usrimages/P/Pix_268.jpg ]
[ Image: http://www.nachi.org/bbsystem/usrimages/P/Pix_295.jpg ]
[ Image: http://www.nachi.org/bbsystem/usrimages/P/Pix_305.jpg ]
[ Image: http://www.nachi.org/bbsystem/usrimages/P/Pix_306.jpg ]
Is it adequate to just cut a hole around the skylight and then caulk it??? that is what i see a lot of...
Jeffrey S. Campbell
http://www.maineshomeinspector.com
Originally Posted By: lkage
No, caulk doesn't belong on a roof...recommend a qualified roofing contractor to evaluate and make needed repairs...would be my suggestion.
"I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
Right… that is exactly what I recommended… then client had additional questions about how is SHOULD be installed… and I want to give a somewhat educated answer…
I see a lot of caulking/silicone on metal roofs that were installed after the fact... around chimneys, skylights, vents etc...
Thanks
Jeffrey S. Campbell
Originally Posted By: rcooke
Unfortunately my experience with metal roofs is that many are installed less then professionally .
( Example the installer!)( I am a handy man and can do anything )
Skylights ? I tell people I like them very much but it is not a case are they going to leak but when are they going to leak.
Again most skylights I see are not installed well.
I do not like inspecting from pictures but I feel these sky lights are far from professionally installed .
I would write in my report.
Sky lights require Further evaluation by qualified person Immediately.
Roy Cooke Sr.
http://Royshomeinspection.com
jcampbell wrote:
then client had additional questions about how is SHOULD be installed... and I want to give a somewhat educated answer...
Can't say really...never seen skylights installed in pole barn raised rib metal. It just isn't right the way it is, that's for sure.
Galileo Galilei
Originally Posted By: Jay Moge
not to mention the possibility that the asphalt roofs’ demise may verywell have been the leaky skylights. so installing a metal roof is just like putting duct tape on a leaky pipe, it may work for now, but wait… icon_wink.gif
Jeffrey S. Campbell
Originally Posted By: dedwards
Have a very good friend who is a superb professional carpenter. His comment on skylights is: “I’ve taken out a hellava lot more of them than I’ve ever put in.”
Originally Posted By: apfaff
Wow, that last pic showed it all. The water would pour between the metal roof and the old roof. That trapped moisture could work its way in every direction. I believe they should have cut the hole smaller and seemed up the edges, then applied additional counter flashing. My father-inlaw is a tinner. He has all kinds of cool tricks to flash this properly. Have it evaluated. Do not tell them to caulk it. I have some experience with pole barns and one thing is for sure caulk does not work. Nether do those little grommets around the nails. Explain to them it was improperly installed and the remedy will require some creative flashing.
Aaron Pfaff
http://www.dedicatedhomeservices.com/
http://www.independentinspectors.org/wisconsin.html
Originally Posted By: mcyr
Jeff;
Hahnel Brothers is right up the street.
Best roofers in the State.
Recommend further evaluation by qualified people.
Can't make a mistake with this one.
A mistake only becomes an error when it can not be corrected.
Try it.
It is resourceful and available, local.
Marcel
Originally Posted By: jkormos
Right on Roy, not if but when, a roof penetration is a roof penetration and a potential source for a leak
