Has anyone done alot of mobile home inspections ? is there any courses on them , anything will be appreciated, any special reporting books, etc.
thanks
Joe
When in the crawl area watch out for electrical wiring and wild vermin.
Look closely for re-done poly plumbing and vapor retarders installed on the warm side in the crawlspace.
See 24 CFR 3280.
This is another link for what Jim posted;
http://www.access.gpo.gov/nara/cfr/waisidx_99/24cfr3280_99.html
You might want to check here also for some help.
http://inspectapedia.com/structure/mobileinspections.htm
Also check you Jurisdiction for tie-down requirements.
Depends where you are inspecting. Assuming this being asked in the Canadian section perhaps consider the points offered by another Canadian inspector such as http://www.allaroundthehouse.com/lib.mno.na57.htm
I apologize Claude, I failed to notice this was in the Canadian thread, but upon reviewing the contents of your link, I do not see where inspecting a trailer in Canada is any different than here in the US.
I respond to anyone in Inachi that needs assistance, if I can help.
The poster asked a question and no listing of the geographic area was listed.
Marcel not a problem, I did not take it as an issue. I agree, however, newer codes - where applicable may be slightly different across Canada.
I also agree, a lot of common concerns from a saftey and habitability POV are shared regardless of the borders.
Cheers, Claude
