Moisture meter recommedation
Looking to see what Moisture meters anyone can recommend. I have a General and I question their accuracy. I like to have a pin and pin less or combo. Thanks! Mike
I think they have calibration tools to test the accuracy of them.
https://www.toolexperts.com/moisture-meter-protimeter-pin-type-bld2000.html
^^^^^THIS ONE is very good.
I use EXTECH MO257 pinless. Ordered through Amazon
I personally like the Survey Master I have. A bit, more expensive but, vary small and has both pins and non-invasive reading capabilities.
The Trotec T660 Material Moisture Measuring Device - Ic-T660 I have found it very reliable for building inspection dunedin
I also have a Survey MAster and I’m very pleased with it. Yes, it is more expensive but it is accurate.
Survey Master
I have used delmhorst for years and loved them the BD2100 is a great set it and forget it pin meter and the tech check plus is a great pinned and pin less. https://www.delmhorst.com/
