Originally Posted By: Mark Anderson
Regarding foundations----
Statements & claims posted on Your websites...
1) The home inspector should examine the Major components & systems of a home which include foundation...The home inspector should then descibe the condition & any significant concerns to the client.It is Very Important to know the True Condition of the house so you can determine its true value.
So if the basement is finished & there is paneling/drywall up then how far are YOU willing to REALLY go to Actually determine the True condition of the bsmt walls?
2) What is an Inspector looking for?
Major defects..such as structural and potential causes of major defects suck as small leaks
What areas are Inspected?
Foundation
Again, if basement is finished and you really care then how are you going to determine condition of foundation...huh? Thats what you claim is inspected and claim its what Your looking for.
3) What I Inspect....
I 'Thoroughly' inspect Everything that makes up a house!!!
Thats right,keep askin` the same question...how ya going to "Thoroughly' inspect Everything if You can`t see everything?
4) A 'Skilled' H. inspection professional has the training & experience needed to look for visual signs of defects in your new home. These defects,if not detected and repaired prior to closing,can cost you,the new homeowner thousands of dollars in repair bills
5) Consumers should be very careful when shopping for a home inspector. The industry as a whole is unregulated &...."many" unqualified people offer home inspections
These are not my words but an HI`s own statement on their website, which i totally agree with
6) A Home inspection is the most expensive commodity you are likely to purchase in a lifetime. ONE Defect "Missed" by your inspector could cost you thousands. The Primary Objective of a home inspection is to provide you with information about the home and "any' Major defects Before you buy it.
Yup.....better look behind that paneling/drywall folks!!!
Harper Woods Mich....home for sale, potential buyer hires H inspector. Buyer worried about 2 different areas w/ block basement walls. 1 area in corner has visible step cracks in corner with quite a bit of mold and efflorescence. Other area under front porch has mold above ground level just under cap. The HI recommends extending downspouts extensions ONLY! States this will sove moisture problem!
I go over and show `n explain that in corner the reason water-moisture is entering block wall and onto floor in because of the cracks in wall which then causes the mold and efflorescence...recommend waterproofing the corner only. Take the time and go 1 step further to actually SHOW the seller and buyer what i mean...go outside `n run the hose at ground level. Within 5 minutes there is water on the floor, end of story.
For the porch we do the same but since mold is up high(above grade) in basement i already know that the moisture-water that is entering and causing the mold is entering from'above' ground level(not the wall). But to make sure, we run the hose First along outside of porch at ground level....nary a drop after 45 minutes. I then show them several openings in some mortar joints above ground level, and explain to them that this will be the problem but will visually show them and run the water into & around the open moratr joints. Within 1 minute there is water on the floor. Entered the cells of the block bsmt wall from the open mortar joints that sit on top of the wall...recommend tuckpointing, end of story. Extend Downspout Extensions???  ..yah, ok.
The Real reasons basements leak
