Morons ](,)](,)](*,)
http://www.drymich.com/about-us/news-events/4683-exterior-excavation-not-the-best-choice-in-basement-waterproofing.html
Just more bulshtt from an inside system co.
Eh shttheads, eyeball my photos and much more often than not, exterior excavation aka exterior waterproofing is not only the best choice its the fcg ONLY choice if one is going to STOP water from entering AND relieve,lessen exterior pressure/weight off the friggin wall and fix any deteriorated,disintegrated blocks and mortar joints and very often stop-prevent mold and efflorescence and fcg insects…radon gas also enters through this shtt
What a crock of absolute BuuuuuuuuuuuuuuuuLLLLLLLLshttt.
Here’s an inside system piece of shtt for you and since it was installed…cracks widening,still leaking,more mold and efflorescence…dumbazz!
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing41
And over $15,000 for this incompetent,fraudulent piece of shtt system.
Click each photo to ENLARGE…use arrow in middle of each pic on RIGHT to forward
Eh…look at this bowed wall and some deteriorated blocks az hole
http://picasaweb.google.com/101049034584960315932/Crawlspace
Here’s a video for yer BUBBLEHEAD AZ, an interior system was installed…see what the fc happened SINCE dumbazz!
G amn scamming,lying,incompetent pieces of shttttttttttttttttttttt!
The piece of shtt artcile is…WRONG, its mis g damm information…and i say and fcg KNOW the drivel written is incompetent nonsense!!!
Underground tree root AGAINST basement wall, corner…caused the cracks and caused the fck leak!!! Your inside system BULLLshHHtTtT doesn’t fix,repair ANY of the above or any other g dammmmmm job i’ve seen/estiamte or done, NOT ONE az HOOOOOO!
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing09
What does your dumbazz do for ANYTHING, any house,wall,problem like these?
N o t h i n g!
And you fcg terds charge as much or MORE $$$, yes you fcg do!!!
And ummm DUHHHH, what happened to YOUR scammball company INSTA DRY, huh???
Out of buisness…so much for those SUPPOSED lifetime guarantees. Man, hate these cheating sobs.
