Multiple neutrals
Originally Posted By: waksell
An electrition told me you can’t put more than one neutral wire per lug on bus bar because if you are servicing a neutral wire you will be interupting the neutral for another circut. All the houses in my nieghborhood have this. Should this be reported as a double tap?
Originally Posted By: Joey D’Adamo
Yes, it should.
Originally Posted By: dspencer
Is permitted IF there are no more lugs available.
Not for the last 2 code cycles
Still what I follow (Our State building inspectors allow this) I never argue the local codes.
Local code books are cheap get one from your building code office.
In Florida there are NO local codes. It is the NEC, as written by NFPA. We got tired of 67 counties and hundreds of cities making up rules as they went along.
Wouldn’t that be nice…maybe someday life can be that easy!
LUCKY YOU! ![icon_exclaim.gif](upload://kW92MliyHA8ygoXI0UsgtBSn4ZO.gif)
Originally Posted By: jmyers
Maybe it is time to tell this fellow that those sparkies can purchase and install more grounding/neutral bars when they do run out. ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Joe Myers
A & N Inspections, Inc.
http://anii.biz
Originally Posted By: gmickes
Greg, i live in sarasota , the city’s and counties here still make up thier own stuff sometimes.
Inspectors do have a problem “intrepreting” codes in a creative way but Sarasota is still on the Florida Unified Building code and that is the 2002 NEC.
Damn thing is if one has a code hand book, it specificaly tells the intent . right?
The code book is only the language of the law, the intent is better found in the ROP but that is not enforceable. When I was inspecting I always tried to identify the hazard. There is always a hazard behind a rule. If you effectively deal with that you have met the intent of the code.
Some building departments will dissagree with that concept but their inspectors are doing 30-40 a day so they don’t have time to really think about their decisions.
It is the main reason why I don’t inspect for a muni.
