New Construction- No clips
Hey all- I’m in North West Florida and did a new construction inspection this morning.
While in the attic, I observed that there were no clips installed at roof-to-wall locations. I did, however, see some along some strongback-type framing (if that’s the proper term), but definitely not at the roof-to-wall areas. I’ve attached some photos to show what I saw.
My understanding is that clips are required at all roof-to-wall locations- does this look like they’ve been forgotten or is there something I’m missing?
It should have been noted during the framing inspection, do they have framing instructions where you are?
Maybe they used something like this?
IMG_0061
Nothing that I have access to.
I’m kind of thinking just making a note in the report suggesting that my client follow up with the builder to get documentation of such a product (if used). I don’t see how an inspector could note roof-to-wall connections on a windmit inspection in the future, and if the owner doesn’t have paperwork regarding some concealed product that was used they’d kind of be out of luck?
I see three nails
Could be a double wrap but pics are not good & clear
We’ve seen a couple of these in new construction and was able to verify with the builder. It meets code, but per the wind mitigation form it goes down as toenail. The form is very specific and until it’s updated or changed there’s not much you can do.
That gusset plate looks damaged from here.
Aren’t most builders switching over to TimberLOK, Stong-Drive SDWC, SPAX, ETC screws?
You need to look at the plans as to what the engineer required.
Hi Brian-
I am in NW Florida as well. Some specific builders are now using Simpson Strong Tie screws which DO meet code. The left hand (state/city building departments) isn’t talking to the right hand (insurance carriers) to come to a solution…and the homeowners are feeling the brunt of it!
Like others have stated: The Insurance carriers don’t seem to care…if you can’t see clips you don’t get credit! It’s ludicrous! It puts us in a tough spot as well.
Our local insurance carriers and new home building association are working with state legislature about this issue as insurance in Florida is very challenging right now to say the least!
Best of luck.
Regards,
Dan
