Anyone seen this type of pipe used for a Dryer Duct.?
Am I missing something here?
**ADS 3000 Triple–wall HDPE pipe is triple–bonded polyethylene for exceptional pipe stiffness. With smooth inner and outer walls and a corrugated structural core, ADS 3000 Triple–wall HDPE pipe is designed to have superior pipe stiffness to that of PVC sewer and drain pipe, yet priced to compete.
Applications within this Market
Foundation Drains
To prevent water from entering and ruining the foundation, install ADS perforated pipe in a gravel envelope around the entire house.
Basement Drainage
Perforated pipe can be installed in new or retrofit construction to prevent wet basements
Driveway Culverts
ADS non-perforated pipe is strong enough to withstand traffic and can be easily and affordably be installed under residential driveways.
Roof Drains
With ADS pipe’s durability and ease of installation, it’s a great for carrying rainwater away from buildings.
Irrigation
ADS Pressure Pipes are flexible and durable, making them ideal for a variety of applications.
I’ve see schedule 10 pvc used before and anything else that they have available, but this was a brand new house.
Draw inspection for the bank.
Never seen this type of pipe used for dryer exhaust with duct tape joints.
New technology escaping me or what.
Might be alright, but can’t find anything to back up my skepticism on the product for that use.
Oh! and by the way, you bring any fleas home from an inspection lately.??:mrgreen:
2006 IRC specifies .016 rigid metal duct only (does 2008 allow PVC?), the ADS literature does not list dryer ducting as an approved use for that product, IRC prohibits the flexible transition connector from being concealed (it may or may not be, hard to tell where it goes after heading up), duct tape should not be the only means of securing joints and the length of the duct is very likely >20’ (25’ - 5’ for the 90°). Other than that it looks great.
LOL no fleas lately . That house was a bad dream for sure . Neighbor hooked their drain to the homes septic system also .
Over 25 feet including elbows?
I guess someone will be changing a nice pipe job. Your a meanie Mr Cyr lololol
Many times the dryer specs allow for runs longer than 25’ which can trump the minimum requirement of the builing code. i pulled the following out of the IRC.M1502 Clothes dryer Exhaust
M1502.5 Duct Construction
exhaust ducts shall be constructed of minimum 0.016-inch thick rigid metal ducts, having smooth interior surfaces with joints running in the direction of air flow. Exhaust ducts shall be connected with sheet metal screws or fastening means which extend into the duct
The technical data sheet for this pipe says you can use standard PVC drain fittings. If thats the case why did they use duct tape? If the joints are not glued or mechanically fastened I would question the use of the tape. Although the length combined with all the elbows is probably the most significant issue. I have advised my clients in the past this long of a dryer vent will requires routine maintenance due to the reduction in air flow. Most people don’t notice a problem until it starts to take longer than normal to dry their clothes.
Duct tape? I know. Long run? yes. Since this was a draw inspection only, I was only paid to take pictures.
Caught my eye because of the type pipe. Thought I was missing something.
Doug, I thought it was 90 degree deduct 5’ and 45 degree, deduct 2.5?
Most of the time the owners manuals are not available for verifying whether or not the dryer is capable of longer runs.
These people are moving in shortly and I forgot to tell him about this.
Marcel,
Even so, it has been my experience that the Draw Companies (Such as Granite and the now defunct DDN) request that you report any Code Violations that you may notice in the course of your site visit. This may not be true for whoever sent you on this one. Wouldn’t hurt to re-read through their inspection guidelines to cover your bases.
Jeff
My understanding is that flex duct is not allowed to pass through walls and floors. This would create the ‘concealed’ condition, as it cannot be observed from one location, ie. laundry area. Irrelevant that it can be observed from the basement/crawlspace.
This was actually done for another inspection firm out of Arizona that takes care of the Bank inspections out of New Jersey.
Don’t ask me how it works, I don’t know.
The email agreement was no inspection items, defects explained in my letter. Pictures only.
They did call me on the unfinished basement part and told them this was half the basement used for mechanicals and the other half was finsished per the pictures starting at the stair access.
They found me through INACHI. Pays only $60, but if close by and 20 minutes to take pictures, it gets my name out there.
Haven’t received payment from end of June yet. Very slow.
I agree, poor installation. They had all kinds of room to come out of the floor and straight to the exterior instead of creating that long run. But, I guess the future deck was in the way.
How do you like these temporary stairs for a couple of years.?
I agree, the IRC even states transition ducts “.… must remain entirely within the room in which the appliance is installed.” I didn’t state my earlier comment very well.
