dnasser
(David Nasser)
The house is built in 2006
200 amp main panel
The house is occupied in great condition.
I seen what looks like #10 wire connected to 45amp breaker. The panel
has that breaker assigned to the Oven…
My understanding is that a #10 wire is use for a 30 amp breaker.
Is this a recommend further evaluation by an electrician? Or does it
look ok.?
Need advice…hopefully the pictures are ok…Photobucket changed
the way you resize the photo’s…
David
mlarson
(Michael Larson, WI Lic. # 1672-106)
2
Fire hazard.
30 A for 10 AWG restistive load.
jwhitt
(Joseph M. Whitt)
4
I agree with this statement
jwicklander
(Jeffrey Wicklander)
6
You said ‘what looks like #10’…was it #10 or #8?
Jeff
rmeier2
(Robert Meier)
7
I thought that too but from the photo it appears to be solid so that means that it won’t be a #8.
jwicklander
8
Does anybody ever trace the neutrals when dealing with mini’s? I see one twin that is labeled kitchen for both and the conductors are red and black.
Jeff
mlarson
9
edited to avoid confusion:
jwicklander
11
What if it’s sharing the same neutral?
Jeff
jwicklander
13
What if it’s sharing the same neutral.
Jeff
mlarson
14
Explain how that is a problem.
jwicklander
15
I’m pointing out that both of these conductors are on a twin breaker.
Jeff
mlarson
16
You are probably right to be concerned. Do you have the code reference?
Jim_Port
(Jim Port)
17
It would be if they were sharing a neutral and are both fed from the same leg. Notice that this appears to be tandem breaker.
If this is two single pole breakers they would need a handle tie.
Jim_Port
(Jim Port)
18
Number 8 and larger are stranded. Since someone said it is solid that would limit it to a #10 or smaller.
mlarson
19
Yes I agree. They need to be on 2 legs not one as shown. My error.
ccurrins
(Christopher Currins, CMI®)
20
[http://images.lowes.com/product/converted/048243/048243263684lg.jpg](http://images.lowes.com/product/converted/048243/048243263684lg.jpg)
8-3 Indoor Non-Metallic
