OK I’ll bite, looks as if the big *** shut off on the left is not the shut off for the open panel with all the fuses in it.
Also seems that there is no dead front for the SE wires.
Could lead to assuming the power had been shut off using the switch to the left but wasn’t?
Also looks like a commercial installation - not residential
I assume the answer you are digging for is that there is no dead front to protect the homeowner from the wiring in the event that they have to change a fuse.
Personally he is not being attacked, so as I have stated before the results would have been different had the attack not occurred. Oh well it is water under the bridge.
I think Len actually had a good question, because there’s actually a defect that can be seen in the photos. I assume he was simply referring to the missing dead-front cover.
There may be additional issues, but seeing that he titled it to attract “newbies,” I will go with the most obvious defect.
The hinged cover is the “exterior cover.” The “dead front” is the interior cover that covers the internal components, while making safe access to breakers/fuses possible.
understood, but it doesn’t appear the one in the pic is designed for a separate dead front. I’ve seen these but never called them out as long as they could close and latch. Is it a defect since there’s no “missing” dead front?
I can see how a person can be shocked (or worse) by trying to replace one of those fuses in the dark.
